Thread: First test results after Bac Conversion
    Jul 2006
    Smile First test results after Bac Conversion
    30,000 gallon Gunite IG pool - probably about 25 years old and I have no idea when it was last refinished. I got it with the house two years ago.
    Last year we used Bacquacil. We switched back to chlorine this year and we've had quite a battle until I found this site and reclaimed my pool following the BBB instructions. I just got my test kit and here are the numbers:
    FC - 3.5
    CC - 1.5
    TC - 5.0
    pH - 7.2
    Alk - 170
    Cal - 510
    Cya - 30
    Temp - 84
    I don't know what the Calcium number should be. Is this low?
    The water is crystal clear and sparkling! However there are a lot of yellowish stains on the sides and bottoms of the pool. The gunite at these stains feels pitted or rough. I'm not sure what these are but got much worse last year when on Bacquacil. Any advice would be appreciated!
    Thanks!
    Default Re: First test results after Bac Conversion
    With a CC of 1.5, I'd definitely shock the pool. Your calcium is a little high (200-400 is recommended), so I wouldn't use cal-hypo to shock or chorinate because you could soon start having cloudy water problems. Otherwise, your numbers look great!
    Jul 2006
    How much bleach do you think I should use for 'shock'? Should I take it to 15 ppm again? What should the CC be?
    Thanks for responding!
  1. Test Results...I think!
    By Dw4scoobydoo in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-07-2012, 10:29 AM
  2. Test results
    By kolwecoon in forum DPD-FAS based testing
    Last Post: 01-15-2007, 04:55 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  5. First results of test kit
    By daverothwell in forum DPD-FAS based testing
    Last Post: 05-14-2006, 09:24 PM
