Re: Does cyanuric break down over winter?...
CYA can be biodegraded in a closed pool by anerobic bacteria. The bacteria will eat the CYA and excrete ammonia and urea. When you open the pool the CYA level has dropped and the pool seems to have an instatiable chlorine demand! It takes a lot of chlorine to burn up all the ammonia compounds before the free chlorine starts holding.
Also, it is very true that testing for CYA when the water is cold can give you a false low reading (as can testing when the water is too hot). LaMotte recommends that their CYA test be done on water between 70-80 degrees. Don't know if Taylor Technoligies has any specific recommendation but since their test is also based on melamine precipitation I would assume the same applies.
