Results 1 to 8 of 8
Thread: Fiberglass Pool
    DONNIE is offline Registered+ Thread Analyst DONNIE 0
    Jul 2006
    Oklahoma
    Default Fiberglass Pool
    Do I need calcium in a fiberglass pool? I've been studying water chemistry to be prepared for my upcoming new IG fiberglass and can't really answer this question.
    Donnie
    Downingtown, PA
    Default Re: Fiberglass Pool
    You need to keep a CH level to prevent calcium from leeching out of the plaster. Based on that assumption, a fiberglass pool should not need to calcium. I may be wrong but that is my feeling. Now if you have a heater I think that you do need to maintain your CH level.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    The only other good reason to keep calcium in a F/G pool is if the manufacturer requires it for the warranty--you don't want to give them ANY excuse to back out of honoring it if you need it.
    Downingtown, PA
    Ahhhh I didn't even think of something like that. Good point Carl.
    Jul 2006
    Oklahoma
    I just checked with the heater mfg and it says to keep TA @ 120-150 which is a little higher than recommended on this site and to adjust calcium to 200 300. Thanks for the tip. I never considered the heater requiring calcium. Just trying to sort all of this stuff out before hand. Any thoughts on the higher TA?
    Donnie
    Jul 2006
    Oklahoma
    Thanks! Now if I can just get over the stress of all this. Maybe a beer will help.............................................. .................................................. .................................................. .................................................. .............................Yep!
    Donnie
    mbar's Avatar
    Ashland, PA
    You will love your fiberglass pool! I run mine with calcium of about 150. I find using the bleach, baking soda, and borax combination works best for my pool. If you have any metals, be sure to put in a sequestering agent - fiberglass pools tend to stain if there are any metals in the water. A sequestering agent will hold the metals in suspension which will avoid pool staining. Other than that you won't need anything else.
    Northeast PA
  1. Off Level Fiberglass Pool
    By Rudy2012 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-05-2012, 07:36 PM
  2. Fiberglass pool
    By Aboabdo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-01-2011, 05:57 PM
  3. Concrete in new fiberglass pool
    By [email protected] in forum In-Ground Pool Construction and Repair
    Last Post: 09-03-2006, 02:20 AM
  4. Getting a new fiberglass pool
    By [email protected] in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-11-2006, 10:45 AM
  5. Fiberglass pool question - can they pop out?
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2006, 01:32 PM
