Re: First Test Results with PS234
Your results are pretty good. I recognize you got your TC result from the OTO test......not by adding FC + CC.
Many, if not most, new kit owners do just like you and go right down the tests one by one (I know I did) and end up with a TC result that is different from the total of FC + CC in the FAS/DPD test.
Most of us don't report both tests...just the FAS/DPD test and let the reader do the math to get TC.
Your salt seems a little high....most SWG's seem to require 3000 - 3600 as ideal but I am not an authority by any stretch....it's just what I've read from other SWG owners here on the forum.
As watermom indicated, don't let your pH slip up into the 8's.
I like the idea of doing FC + CC to get my TC. It's alot easier than trying to match up the colors.
As for the salt, we've got a IntelliChlor Generator and it's suppose to have a green flashing indicator light on the control panel if it goes above 4000, right now it's a solid green which should be in the 2900-3900 range. So maybe I messed up on the salt test. I'll try again and see what I get.
Thanks again for the advice.
