Results 1 to 10 of 59
Thread: White Cloudy Water - Twighlight Zone
    Default Re: White Cloudy Water - Twighlight Zone
    You have gotten some good advice in this thread and appear to be well on your way to keeping it clear for good. This thread is getting pretty long - up to 53 posts I believe. Since I think you have probably gotten the info you need, I'm going to go ahead and lock this one as it is getting a little unmanageable. Congrats on the good work!
    PS - Raining here too!
    szampino is offline Registered+ Thread Analyst szampino 0
    OK.
    I thought there might be some benifet to see if the Cloudy Problem re-occurs before closing it out.
    Some of the last posts were to drain and begin again.
    Your call!
    Revived POP
    Intex Blow-up Ring 18x48 round
    Cartridge Filter
    scorecard
    7/29/06 - 9:00am.
    FC- 15
    PH- 7.2
    Woke up this morning and the water had turned a little "Metally greenish" (yellow/brown against White and Blue vinyl).
    Chlorine held overnight so I am assuming that I do not have an algea bloom and this is due to the metals in my water.
    I added about 1lb of AA. This should bring my Chlorine down but I haven't checked yet.
    As of 12pm - the water is now crystal clear.
    Q. Should I bring the water back to shock level or can I get it to swim range about 2pm (due to the metals).
    Any and all thoughts welcome.
    Revived POP
    Cartridge Filter
    scorecard:
    7/29/06 - 4:30pm.
    FC: dropped drastically to about 1ppm
    PH: also dropped to about 6.8.
    I've added about 2qts of Bleach - Using the guide it looks like 1 gal of 6% bleach should bring 10,000 gal up 5ppm, will wait a little while then add 1lb of Borax.
    Will try to get my Chlorine level up to somewhere between 2 -3.
    Still not sure if I should bring it to shock?
    Revived POP
    Cartridge Filter
    Scorecard
    7/30/06 - 12:20pm
    FC - 3
    PH - 7.2
    I can't believe it but I think I'm done! It was long, painful, but the water is now Crystal Clear!
    I need to send a BIG THANK YOU to everyone that helped!
    This thread can be closed!
    Revived POP
    Cartridge Filter
