Results 1 to 10 of 59
Thread: White Cloudy Water - Twighlight Zone
    szampino is offline Registered+ Thread Analyst szampino 0
    Default Re: White Cloudy Water - Twighlight Zone
    scorecard
    7/29/06 - 9:00am.
    FC- 15
    PH- 7.2
    Woke up this morning and the water had turned a little "Metally greenish" (yellow/brown against White and Blue vinyl).
    Chlorine held overnight so I am assuming that I do not have an algea bloom and this is due to the metals in my water.
    I added about 1lb of AA. This should bring my Chlorine down but I haven't checked yet.
    As of 12pm - the water is now crystal clear.
    Q. Should I bring the water back to shock level or can I get it to swim range about 2pm (due to the metals).
    Any and all thoughts welcome.
    Revived POP
    Intex Blow-up Ring 18x48 round
    Cartridge Filter
    scorecard:
    7/29/06 - 4:30pm.
    FC: dropped drastically to about 1ppm
    PH: also dropped to about 6.8.
    I've added about 2qts of Bleach - Using the guide it looks like 1 gal of 6% bleach should bring 10,000 gal up 5ppm, will wait a little while then add 1lb of Borax.
    Will try to get my Chlorine level up to somewhere between 2 -3.
    Still not sure if I should bring it to shock?
    Revived POP
    Cartridge Filter
    Scorecard
    7/30/06 - 12:20pm
    FC - 3
    PH - 7.2
    I can't believe it but I think I'm done! It was long, painful, but the water is now Crystal Clear!
    I need to send a BIG THANK YOU to everyone that helped!
    This thread can be closed!
    Revived POP
    Cartridge Filter
