Closed Thread
Results 1 to 10 of 17
Thread: water level dropping
    Default Re: water level dropping
    STILL Need HELP! We did get something to work to get the dye to the bottom, Thanks, Al. I have put dye at all of the skimmers and inlets, all around the seams where the wall meets the bottom, and the bottom drain. with nothing that I can tell is leaking. I have taken measurements and seem to be losing about 1 1/2 inches a day, seems to be the same with the motor on or off. This seems like a lot to me, and that it should be pretty obvious when the dye gets close, Am I right? The filter and motor are 2 feet higher than the deck of the pool and I am not loosing the pressure in the filter, if that makes any difference. I am going to turn the filter on with just the bottom drain now and see what happens. My next ????? is Where is the next most likely place to be leaking and what else can I do??? HELP!
    Honesdale PA
    That rate of 1.5" a day is about 2 quarts per minute so that should be detectable if it's a single leak. I'm wondering about that bottom drain. If it's leaking out of a pipe then you probably won't find it with dye unless you can inject at the pipe opening somehow. Don't have one, never saw one apart, so don't know if getting to the pipe is possible.
    Anybody out there know about this?
    There are companies that use electronic leak detectors to find pinhole leaks in liners. Not sure exactly how they work but they rely on the leak forming a conductive path between the water in the pool and the outside world.
    Only other suggestion I have is to let it drain and every 6 hours or so make as precise a depth measurement as possible and see if the leak rate changes. I let mine drop about 1 foot I believe, and in my case the rate didn't change so I figured it was a deep end leak. As the water level drops and approaches the leak you should see a decrease in leak rate. This can give you an idea if it's at the shallow or deep end and at least may narrow the search some.
    Unfortunately I'm out of more ideas at this point.
    St. Louis, MO, USA.
    Do you have a light in the pool? I have heard that vinyl liner pools often leak around the lights. Might be worth trying a dye test there.
    ~Rick~
    18,000G freeform gunite; PebbleSheen; Sta-Rite System 3 Cartridge; Sta-Rite heater; Polaris AutoClear Cl Generator; Polaris 380 cleaner
    Default Re: water level dropping Found leak!
    Well, I gave up and called someone to find it. It was a liner leak in the corner of the deep end where the wall meets the bottom. He even pointed it out in the first few minutes without getting in the pool! It was very obvious even to me. I guess we just missed it, or I really wasn't sure what I was looking for. Cost $225!!! but, I think I really liked him, And would use him again for anything we couldn't do ourselves. He looked over everything else while he was there and didn't find any other leaks, seams were good, and everything else is in great shape. He thought my PH was a little off and asked if I use CHlorine. I said yes--- well I do, but I just didn't want to say it was Bleach. He tested my chemicals and said everything was PERFECT! Couldn't be any better. Of Course I knew that. He told me Sams has a 100lb bucket of granular 99 % chlorine with no added fillers for about $100-- $1 / lb. Sounds good, but I am sure bleach is still cheaper and I am sold on the bleach method.
    Thanks for all the help, and now I have my dye contraption all ready for the next time.
    Honesdale PA
    Carolynn,
    Glad the problem is fixed. Bet you learned a lot in the process like I did. Next times are always easier. $225 doesn't sound bad at all. Just for our education I'm curious how he laid the patch.
    Oh no, I missed how he put in the patch!!! I had a tree guy there at the same time to take out a tree that died and could fall into the pool if it fell. He just happened to show up at the same time. All I know about the patch was that he used a piece of the left over liner cut out of the steps to patch the hole. Now, if I get another hole, what do I do??? That is if I can find it the next time. Oh well, I am out of town now, and the people at home tell me the pool looks great, no water loss at all! They are putting bleach in as scheduled!!! Thanks everyone for your help. I love this site!
Closed Thread
