Good morning,
First of all, Janet (and Huenix) has given you a really good synopsis of the conversion. I would like to add (or pose the question) about the timing of the bleach addition. First and foremost, remember, I am a cheapskate!!![]()
I think it is prudent to add as much bleach as possible during the evening. That way, the sunlight destroys as little as possible. I would think something like this would be reasonable:
1 hour before sunset, bring your Cl up to around 16-20ppm...it'll start to drop immediately. Then shortly before you go to bed, retest and bring it back up to 16 - 20ppm. Try to get up an hour or so before sunrise, do it again.
Hopefully, you can come home at lunch and repeat.
Start the above process over just before sunset the next evening.
This way, you only have one bleach application exposed to the sun and will get the most bang for the buck from your Cl and you will still be getting four shock value applications in a 24 hou period.
And, as Janet said, you will probably lose most any Cya you add now so wait 'til your conversion is complete.![]()
