Re: Why is a chlorine floater a bad idea?
Everyone here will suggest you get your own test kit and do the tests yourself. Then you can believe the numbers with higher confidence.
With the CYA at about 80, you are a the minimum FC level to keep algae at bay. According to Ben's chart, http://www.poolforum.com/pf2/showthread.php?t=365 , you should probably keep it closer to 8ppm.
