Results 1 to 10 of 37
Thread: Can my pool stay home alone for 10 days?
    Lehigh Valley, PA
    Default Re: Can my pool stay home alone for 10 days?
    What an interesting thread and applicable to many of us. Like Amy in Raleigh, we live out in the boonies and couldn't possibly ask anyone to come and care for the pool during our absence. My husband, also named Richard and also a chemist, likes Richard's scientific approach, of course. I like the strung up bleach bottles, an elegant and inventive fix.
    Quote Originally Posted by tenax
    i just got back from 8 days away with temps in the mid to high 20's everyday i was away.
    That would be Centigrade, yes? Because if it's Farenheit you're keeping your pool open even longer than we do
    pool was covered with a solar cover for the whole period, timer was set for 2 -6 hour cycles each day,my normal. what i did was dumped in a full jug of chlorine night before i left then 2 pucks that morning (big round ones)
    Question about using the pucks in the floating dispenser with a solar pool cover. Our solar cover is also cut to fit the water surface. I liked the suggestion of tieing the floater to a string to keep it from touching the sides of the pool, but won't the solar cover prevent the floater from floating?
    We're going to be gone for several days and we cannot leave the pump running, and we don't have a timer. Hence, either the floater or the suspended bleach bottles sound like a decent solution.
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Anna, is your pump 110V? Mine is and I use a <$20 timer from ACE Hardware. I feel strongly that some circulation is important and even if you only run it for a couple hours a day it can help.
    I think you could get away with pushing the floater out away from the side of the pool before lowering the cover on it.
    Chuck
    Lehigh Valley, PA
    Quote Originally Posted by ChuckD
    Yes, it's a 110V but it's hard wired. There's no way of plugging in a timer. Eventually, we'll hire an electrician to either wire in a timer or to change the setup to a plug-in, but for now, things are as they are
    Ok, thanks. A load off my mind.
    Ontario.
    10 days can be a long time, despite the best laid plans, etc., you can easily be looking at a discoloured or green pool. Lots of variable, including hot spells. What I do is buy the regular sized bleach containers and have whoever is feeding the cats while I'm away put in a jug every two days. Mark dates on them with marker if you want. The idea is to keep it really quick and easy for them, and I know the chlorine level is good. For this period of time I figure keeping the Chlorine high enough to prevent a bloom is the #1 thing, and I can balance out PH, etc. after I'm back.
    This is for an inground 32x16, so if yours is smaller, space the jug to 3 days or whatever you need. I also invite them to use the pool as much as they want, as I like to have it stirred up. My pump is on 24/7 since I don't have a timer. It's cheaper and easier than having to shock, filter and vacum a pool back from a mess.
