Thread: Baffled by Cloudy Water
    Default Re: Baffled by Cloudy Water
    You said a lot of dust was blowing into the pool. Maybe try turning off the pump and seeing if a lot of it will settle onto the floor and then try and see if you can vacuum a lot of it out. Go very slowly with the vac head or you'll just stir it up again. Also, watch that ph. Definitely don't want it any lower. Alk is ok at 150.
    Bald Eagle is offline ** No working email address ** Bald Eagle 0
    Jul 2006
    The brown color is gone and the bottom of the pool is clean, no more dirt. The color now is kind of a milky cloudiness.
