Thread: Test Results
    Saint Paul, MN, USA.
    Default Test Results
    Hi, newbie here. I have been reading all the other posts and I'm still confused on my test results today. Here's what I've got:
    Intex - 3500 - 3700 gal
    Solar Cover
    Test kit: Walmart 6-Way
    TH - 200 ppm
    FC - 0 ppm
    PH - 8.4 ppm
    TA - 180 ppm
    CYA - 30-50 ppm
    If I'm understanding correctly, my PH is high? Whenever I test my FC is always "0" as well. Any information would be appreciated.
    Default Re: Test Results
    You are right that your ph is high. A good range for ph is 7.4-7.6, but anywhere between 7.2-7.8 is OK. You can use some muriatic acid to lower it. You also need to get some chlorine in your pool or it is going to turn green! With a cya of 30-50, you need to maintain chlorine between 3-6 all the time. Use the bleach calculator at the following link to determine how much plain, unscented laundry bleach you should add. In the upper left-hand corner you will find other calcs.
    http://home.earthlink.net/~mwsmith70...achCalc262.exe
    Also, read through a lot of other posts on the forum and at the sister site www.poolsolutions.com. Welcome to the forum!
    Wink Re: Test Results
    Thank you, Watermom. Could you please repost the calculator link again. I can't get the previous link to come up.
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
