Thread: does shocking kill algae ?
    Default Re: does shocking kill algae ?
    Don't add any algaecide in the meantime. Most make more of a mess than they do anything good.
    Shocking once may or may not kill algae, but, maintaining sustained high cl levels will -- if you maintain it high enough to compensate for whatever your cya level is. That is why we need a complete set of current water testing results taken with a drops based kit - no teststrips.
    But, ultimately, yes- shocking will kill algae and then you have to be sure to maintain proper chlorine levels to keep it from coming back.
    Los Angeles, CA
    DONT USE ALGAECIDE!!
    Im a new pool owner and using Algaecide last week messed up my pool! I cant get rid of the thick film of foam that has developed.
    Take this forum's users advice.
    thanks -
    len
