Results 1 to 10 of 19
Thread: Cloudy - shock????
    Default Re: Cloudy - shock????
    Just a guess, but there might be a problem with the filtration/circulation. Your numbers do not indicate cloudiness from the TA/CH/pH combo. Carl is right that adding either calcium to your pool (as with Cal-Hypo) or adding soda ash (sodium carbonate) to raise pH will often cloud the pool, but normally this goes away relatively quickly, especially in your situation with your pool water balance.
    If you've got suspended particles causing the cloudy water, then your filter should normally clear that out which is why I brought up your checking your sand filter to make sure it's operating properly. I don't have a sand filter so don't know how to see if it's working correctly, needs backwashing, etc. so others will have to help on that front.
    Richard
    rferrel1 Guest
    adding regular Clorox bleach 6% since mid-July. I backwashed the filter last Friday - actually the day before the cloudiness appeared. Pool/filter is only 2+ months old - water went into pool Memorial weekend. Got fairly "cursory" backwash instructions from the install guys but they are local so I could have them come back out. I do have the manual and as best I can tell I am following instructions correctly.
    Is it possible I'm not running the backwash long enough - I'm waiting until the water clears and then rinsing for 30 seconds after. Any other suggestions. I did use the 3" Wal-Mart brand pucks in an autochlorinator until mid-July - just until my CYA got up to the 40-50 range. The autochlorinator is hard-plumbed in. I still have it "open" with no pucks in - should I set it to 0 (i'm guessing this really doesn't matter since there are no pucks in the chamber) I know my sand filter is a Sta-rite with a 1.5hp pump but couldn't tell you the size etc.
    When I vacuum (automatic Lil' Shark) I've been vacuuming to "filter" - should I vacuum to waste??
    Sanford, FL
    Try getting some skimmer socks from Wal-Mart - or just cut the ends off some old nylons and put it on the skimmer basket.
    Also - how long are you running your pump/filter a day? You need to make sure that you are circulating double the volume of water everyday.
    Another thing you can do is purchase some DE and put some (I think a 1/2-1 pound) in your skimmer. This will go directly onto your sand filter and help filter out smaller particles. Be aware that when you backwash - all of the DE will wash out - so I would try this last.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    rferrel1 Guest
    thanks for the suggestion - I'll try the "skimmer socks" - I've already been doing the old nylons thing whenever I cut the grass around the pool.
    For the last week I've been running the filter 24/7. Last night I vacuumed the pool (definitely some green on the bottom which has me puzzled as the chlorine has checked as low as 2 over the last 3 weeks but never lower) and then backwashed for a full 5 minutes/rinsed a full minute. Added water overnight as well as an additional 3/4 gal of bleach per the bleach calc - chlorine was 12.5 when I got home - that got it up to 18.
    Checked this a.m. and it was 17.
    Filter still going - will vaccum again this evening. Still kinda' waiting to hear if I need to add BS to get the TA up.
    It wouldn't hurt--I'd get it up to the 80-90 range and see how that does for you.
    mbar's Avatar
    Ashland, PA
    I would keep the chlorine up at 15 for a while longer - be consistant, don't let it fall until it holds steady overnight. Your water will clear with the high chlorine levels.
    Northeast PA
    Can you swim with chlorine levels that high?
    rferrel1 Guest
    Just reporting in - water finally cleared yesterday. I did end up putting some 3" pucks in the autochlorinator because due to the 2 full 5min backwashes/1min rinse cycles, my CYA had gotten down to around 30. Thanks for encouraging me to stick with the consistent shock level as I'm quite sure that's what eventually solved the problem. robin
    Since your cya is 30, you are fine to use the pucks for a while. But, keep an eye on the cya level. It is amazing how quickly the trichlor pucks can cause it to get to a level that is higher than you want. 30-50 is what we usually recommend. I like mine 40-45.
    stma is offline Registered+ Thread Analyst stma 0
    Poconos, PA
    Hey Rob:::
    I'd bring the TA level up with the baking soda...little at a time directly into the skimmer....
    try this tonite though:
    When the sun goes down, shine a flashlight into the water and check if you can see the tiny particles that in fact make up the "cloud" in your cloudy pool....If so, the nylon sock should do the trick....but be sure to check the sock every so often so it doesn't clog the skimmer then ultimately the filter.
    After doing such, perhaps you may want to shut the filter down for the nite to see if the cloud settles to the bottom of the pool....Although I would NEVER reccomend a pool store for ANYTHING, you may want to get a clarifying agent to see if that can bring the "cloud" together.....
    I feel your pain....BELIEVE ME !!!.....(but that's why God created Budweiser)
