Results 1 to 9 of 9
Thread: any suggestions on using a cover on a small AG?
    Indiana.
    Default Re: any suggestions on using a cover on a small AG?
    Any dirt that gets on the cover would have gone directly in the pool if the cover wasn't there.
    jonv112 is offline ** No working email address ** jonv112 0
    Toronto, Canada
    Well, I now try to keep my cover on all of the time except when adding chemicals, as the water problem is alot better with my solar cover.
    Chattanooga, TN
    Quote Originally Posted by jonv112
    how do you keep the cover from laying on the water and collecting rain?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump, Sand Dollar sand filter, Polaris 65 vacuum
    Toronto, Canada
    Actually, the water does collect when it rains, but none of the water on the top is from the pool, as there are only 4 very miniscule holes that are supposed to drain the water about 80cm from the edge of the wall, so the rain water is sort of "separated" from the pool water underneath, so I just have my dad help me take off the cover, water and all, without anything gettine into the pool. I also use a bucket if there is alot of water on top after heavy rain.
    I agree that solar covers can be a real pain, but their main purpose is to keep heat in the pool. It is amazing how much heat an uncovered pool loses at night.
    Chattanooga, TN
    Quote Originally Posted by JohnT
    Well... yes. That's why I asked how to stop it from doing that.
    If the cover would not lay on the water and be supported slightly into a small dome then very debris would get in the pool when I removed the cover.
