Re: Just Filled Pool Please help with BBB.
Hi Janet, I also posted the same querie at the Garden Web and I got this reply but between both of them Here is where I'm still lost.
I was advise to do this: I ready to comply but I don't understand a few things. Also Does the order matter? If so do I do it:
CYA, Clorine, Muriatic Acid, Baking Soda. Also I know that I have to wait a week before retesting and applying more CYA if needed, but can I apply the bleach, Muriatic Acid, and Baking Soda back to back maybe a few minutes from each other?
3#, 9 oz of CYA ( Does this mean 3 measurements of 9oz each?) This would total up to 27oz of Cyanuric acid/stabilizer/conditior.
So how do I figure out how much is .6 gallons? Is there an easy formula to figure out this measurement?
24 oz. of muriatic acid ( Okay, and Clear on this part.)
14# and 11 oz. of baking soda ( Unclear on 14# What does that mean?)( Does it mean 14 measurements of 11oz each, so it will total up to 154oz of Baking Soda?)
I did try to use the Bleach Calculator and its a bit confusing since I only 2 out of the four requested boxes.
It request:
Pool Size Gal : 15085.24
Chlorine Strenght: 6%
Quantity of Bleach (Gal): ??? I have no idea...
PPM increased Desired:??? I have no idea...
Yikes, this pool chem is extremely confusing.
Thanks for your help it is deeply appreaciated.
Sincerly, Elsa. ( I guess you can tell I'm going nuts!!!)
