Results 1 to 4 of 4
Thread: Phosphate confusion
    Default Phosphate confusion
    Went to the pool store to have the water tested to compare with my test results
    FAC 2
    TAC 2
    PH 7.2
    TA 70 added baking soda
    CH 120
    CYA 25
    TDS 500
    Phosphates 2500
    Ok so the water is perfectly clear couldn't be more clear no residue of any type no algae; couldn't ask for anything more easy to maintain etc
    So what about this phosphate I have read not to worry
    "Finally, to use a phosphate remover when there is not an algae problem even with high phosphate levels in the water is, IMHO, just wasting money on a product that ultimately has no effect on your pool. Same idea as putting in copper to prevent an algae breakout when the water is clean. You are using a product that is not needed to correct a problem that is not present in your pool. If it ain't broke, don't fix it!
    What should I believe
    Default Re: Phosphate confusion
    Your numbers look pretty good. You could tweak a few just a little. PH is OK at 7.2, but if it drops any lower you'll want to add just a little Borax to get it back between 7.4-7.6. Make sure you keep your chlorine between 2-5. What type of pool is this?
    Forget about the phosphates. Go swimming!
    Smile Re: Phosphate confusion
    Thanks For the info Watermom
    Its a fiberglass pool, couldn't be happier with the ease of maintaining it
    waterbear's Avatar
    St. Augustine, Fl
    My phosphates run between 2000-3000 ppm as tested with the Hach phosphate test kit. I have never had algae.....don't waste your money on phosphate removers. Also, ignore TDS measurements...They have little or no bearing on your water chemistry.
  1. Pool test kit confusion - help!
    By SurfaceDreamer in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2012, 01:00 AM
  2. Chlorine confusion
    By GregP in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-18-2012, 07:33 AM
  3. Phosphate confusion
    By aguaguy in forum Dealing with Algae & Slime
    Last Post: 08-23-2006, 08:22 PM
  4. Help.....Im in conversion confusion
    By chlorinebound in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-05-2006, 12:17 PM
  5. Chlorox Bleach Confusion
    By derrikm in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2006, 10:46 AM
