Results 1 to 10 of 10
Thread: New Pool how much chemicals??? (BBB)
    duraleigh Guest
    Default Re: New Pool how much chemicals??? (BBB)
    I'll help you get started.
    1. ASAP, put in 4 lbs of stabilizer....it'll help you hold the chlorine.
    2. After the Sun is off the pool this afternoon, put in one large jug (1.42 gal) of unscented 6% Clorox. That should get you to about 7ppm but it will not last because the Sun will eat it up tomorrow AM. Plan on adding enough to keep your chlorine level between 3-7ppm constantly.
    3. Read every sticky on the forum. It'll tell you what you need to know about your pool water.
    4. Everything else is okay for now. You'll have more questions as you read the stickies but focus on keeping your chlorine level 3-7ppm and get that stabilizer in there......it'll take a few days to be effective. 'Til it does, you'll probably be consuming a large jug of bleach daily. Disregard you Br test results.
    Jul 2006
    GA
    thanks for the Info.
    4 lbs of stabilizer?????????? I have 3" tablets for one of those floaters
    how many do I need????? oh and do I have to have the pump running while adding the bleach????? (My pump is set for 6 hours during the night from 12:00 AM to 6:00 AM).
    thanks again Sissy
    Sissy in GA
    16x28x4 AG Doughboy
    When he recommended adding 4 lbs. of stabilizer, he meant buying some cya (cyanuric acid, also called stabilizer) and just adding it directly to your skimmer while the pump is running. It dissolves slowly in your filter, so you'll need to be patient and give it a week before rechecking your stabilizer level or backwashing your filter. The trichlor tabs do contain stabilizer, but since you have a stabilizer reading of 0, it will take awhile before the tabs build it up. I don't use the tabs, instead just add some cya.
    Yes to having the pump running when adding the bleach.
    Jul 2006
    GA
    alright I started pump and added unscented 6% Bleach 1gal. and now
    my what was absolutely crystal clear water is turning green HELP!!!!!!!!!!!!!!!!!!
    Sissy
    Sissy in GA
    16x28x4 AG Doughboy
    Jul 2006
    GA
    metals?????????? what kind of metals and if so what then?????????
    I'll have green water?????????? does it hurt anything???? what can I do????
    Sissy
    Sissy in GA
    16x28x4 AG Doughboy
    Jul 2006
    GA
    ..........which makes me think.......wejust bought the house 3 months ago and had a full blown watertest done. What do I have to look for????
    Sissy
    Sissy in GA
    16x28x4 AG Doughboy
