Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Strange pH test
    Mandeville, LA, USA.
    Default Strange pH test
    I ran out of the Taylor Phenol Red reagent (R-0014) tonight so I broke out a new bottle. When I tested the pH with that I got a color that didn't match anything on the color comparator; it was a much lighter pink. It's clearly pink but light like the orangey/yellowy colors at the lower end of the pH scale. I ran the test a couple more times with identical results
    My pH last night was 7.5 Free chlorine is 3.0 so that can't be having any affect. (Alkalinity is 50 ppm and calcium hardness is 260 ppm; not that those can be a factor here.)
    The reagent was purchased this past spring as part of a refill kit from Ben.
    Is this just a bad bottle of test reagent?
    Thanks in advance for any help.
    Default Re: Strange pH test
    You might be using the wrong reagent.
    R-0004 is used in the Taylor 2000 series pro test kits. (Bens too.)
    R-0014 is used in Taylors 1000 series residential kits which have a cheaper comparator.
    Hope this helps
    George
    Quote Originally Posted by GHM
    Hope this helps
    George
    you got this one backwards
    R-0004 is used in the Taylor K-1000 and Ben's kit (which included a rebranded K-1000) (smalll pH comparator cell)
    R-0014
    is used in the K-2000 series (K-2005, K-2006, etc.) (Large pH comparator cell and Acid/Base Demand tests)
    Sounds like you used the wrong reagent for your comparator!
    Honesdale PA
    Guess I've been doing it wrong for years like George.
    R-0004 used with the 44 ml comparison tube (Taylor K-2006 & PS-233)
    R-0014 used with the small sample tube.
    George is right.
    Poconos, you beat me to it. When I read Waterbear's reply, I thought he was backwards. Was getting ready to go check just in case my mind was playing tricks on me. You saved me the trouble of getting up and going to look. Thanks!
    Not only didn't I read the numbers on the bottles carefully, I also failed to see that it clearly says which comparator the reagent is for. As you all surmised, I replaced the 0004 with the 0014. What a maroon.
    Thanks for the responses.
    Quote Originally Posted by Poconos
    George is right.
    Thanks Al
    George
    I can't believe someone gave me a negative reputation because someone else thought I was wrong! (guess who)
    Thanks a lot
    Sure doesn't incourage me to post anymore.
    Quote Originally Posted by waterbear
    R-0014
    Egg on face....typed it wrong. it's the other way around! But I realized what KurtV had done....he had used the wrong reagent for the comparator.
