Thread: Lowering PH with Acid
    Michigan
    Default Lowering PH with Acid
    I am attempting to lower my TA but my PH needs to get lower 1st. I found the sticky on lowering the TA but can't find the info on the acid to lower the PH. I know there is something out there that explains exactly what to buy and how to add it to the pool but I can't find it.
    duraleigh Guest
    Default Re: Lowering PH with Acid
    Muriatic acid. Dosage can be found in bleachcalc.
    Michigan
    Default How do I add ??
    So if I go to the hardware store they will have Muratic Acid ? (Liquid) Do add it strait to the pool ?
    Dothan Alabama
    Hardware store, Lowes, Home Depot all should have muriatic acid. I add it slowly in front of a return jet. Be careful with it - it's pretty nasty stuff.
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    Not sure why but it's in the Paint Department at Lowes & HD.
    Yep --- it is nasty --- Also eats concrete (the lime I think)
    27038 Gallon InGround, Vinyl, DE filter.
  1. lowering Ph with citric acid
    By purplegirl in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2011, 05:36 PM
  2. Lowering CYA
    By jrsdws in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-21-2011, 05:39 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. Lowering pH with CO2
    By Jakebear in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-08-2006, 08:22 AM
  5. Lowering Alk in Hot Tub
    By csevel in forum Dealing with Alkalinity and Calcium
    Last Post: 07-04-2006, 11:53 PM
