Thread: Polaris 65 return adapter question
    Question Polaris 65 return adapter question
    My sister-in-law has a Polaris 65 that came with her pool. My question is do most of you leave the adapter for the polaris in the return all the time or do you take it out and put the eyeball back in after each use? I trust the opinions here and know you won't steer me wrong. Thanks a bunch, Penny
    Default Re: Polaris 65 return adapter question
    The Polaris return adaptor for the 165 (the bigger version of the 65) is designed to be left in place all season. However, I don't think it performs quite as well as an eyeball. The only drawbacks I see to constantly swapping it is time and the stress it puts on the adapter--you may break or damage it changing it so much.
    I don't use my Polaris 65 anymore, but when I did, I removed the adaptor when not using it. I like to be able to aim my eyeball where I want to. Sometimes at the top to skim floating stuff and head it into the skimmer and sometimes more downward for better circulation.
    Jul 2006
    Minnesota
    I don't have the Polaris 65, I have the Turbo Turtle but I assume that the connection is the same. I was able to purchase an eyeball that attaches to the Polaris return adapter, in the same way the hose attaches.
  1. Strainer / floor drain adapter for vacuum hose
    By coultond in forum Pool Equipment & Operations
    Last Post: 05-27-2012, 10:02 AM
  2. Intex 1.5 inch hose adapter
    By brian2170j in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2011, 11:45 AM
  3. Polaris 360 Return Line Filter Screen Problem
    By ChiInSFO in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-05-2006, 05:55 PM
  4. Return jet question...
    By court475 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-21-2006, 04:29 PM
  5. Polaris 380 into a return line???
    By LucyP in forum Pool Equipment & Operations
    Last Post: 04-17-2006, 01:18 PM
