Thread: need a easy answer???
    Default need a easy answer???
    Was just looking for a leaf net @the pool store, thought i test the pool people, about switching over from baq to chorline, they said i needed to put something called shock and swim (monopersufate???) that would get the baq out, he said if i put shock in it will turn orange and brown. not switching till may need a easy answer do i or dont i.
    Default Re: need a easy answer???
    To convert to chlorine, just add bleach. Yes, your pool will initially turn all sorts of funky colors - greens instead of orange. But, after a few days, it will clear right up. Go and read through a lot of the old posts in the baq forum and you'll find step by step directions as well as a lot of success stories.
    thanks for the reply just ran out to vac up some more leaves, i understand but what is that stuff he's trying to sell me
    That stuff he's trying to sell you is non-chlorine shock. You don't need it, if you're trying to convert to chlorine, then skip the non-chlorine stuff and use chlorine...bleach, like Watermom suggested.
    got it!! might need some more answers about converting, will post on a nice snowy day!!!
  1. Difference Between Liquid Chlorine and Household Bleach
    By sun and water in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-03-2012, 08:32 AM
  2. Newbie, I think I know the answer but....
    By healthservices in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 11:42 AM
  3. Cant Find Answer Now
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-28-2006, 11:19 PM
  4. SAM vs JAZZ Need quick answer
    By columbo in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 05:25 AM
