Results 1 to 10 of 16
Thread: Draining Gunite Pool
    Default Re: Draining Gunite Pool
    Like what jonv112 said, you don't want to drain. As the rain is starting to come back, the water table is probably going to get high quickly.
    If you're draining because you're going to redo your pool, then that's different as you can have pressure relief holes drilled so your pool's concrete doesn't get cracked and the whole pool doesn't float.
    Nonetheless, the answer to your original question is that a simple sump pump can empty out a pool just fine (but it may take more than a day) and you'd have to know the regulations in your area as draining water has to be done properly, too.
    Quote Originally Posted by 105ex View Post
    No, it is a brand new pool. I'm just trying to get the paint out that the pool guy got in the pool. I've got a pump and I'm on a lot of land. It actually hasn't rained here in about 3 weeks. Other than drilling holes, can I get this paint out some other way?
    Socal_biker Guest
    A submersible pump will do just fine.
    It's what I've used to completely drain my pool a few time over the decades. You can get them cheap at Harbor Freight OR rent them from Home Depot. For what you pay in rental from HD, you can buy the unit from HF.
    Similar model to what I have:
    http://www.harborfreight.com/cpi/cta...emnumber=45019
    The Harbor Freight website doesn't list all their submersible pumps, if you can go to a local store, they'll have over a half dozen models to chose from. The pool vacuum hose will fit the HF pump just fine.
    Quote Originally Posted by Socal_biker View Post
    I've got a pump from a contractor that is real fast and will only take about an hour to drain the pool.
    However, given what others have said, I'm concerned the concrete could crack. Did you have any problems with that at all?
    SeanB. is offline --General User-- Weir Watcher SeanB. 0
    Missouri City, Texas
    Quote Originally Posted by jaypool View Post
    We have some friends, who upon bad advice from a pool store, drained their pool to solve an algae problem. They drained it and immediately filled it from a fire hydrant.
    If draining is the only solution, a quick fill might help prevent floating your pool.
    Site owner -- www.troublefreepool.com
    y0manda is offline Registered+ Thread Analyst y0manda 0
    If a pool doesnt have pressure release valves that keeps the pool from floating and it has not rained in a long time. will a pool still pop out or float? I am curious about this question too. Would the plaster crack even if the pool is lets say at least 6 months old? Is their still enough moisture under the pool from the pool it's self or does ALL the water in the pool stay there and not past the plaster? I have asked myself this question, If I were to look under the pool while the water is still under there, Is the dirt completly dry? Just wondering. Thanks.
    I am thinking I am going ahead to try and drain it to get the paint out of the pool. Does anyone have an idea on how to do this any other way?
