Results 1 to 10 of 10
Thread: PH Question
    cnk is offline ** No working email address ** cnk 0
    Default Re: PH Question
    So how much Borax would I need to add for a 12,500 gallon pool? Do I need to bring the PH down before or after adding the Borax? I tested my tap water & it has a PH of 7.2 so it's not naturally high.
    Quote Originally Posted by cnk View Post
    3 3/4 lbs of borax and 1 at of muriatic acid per 1000 gallons will raise the borate level to 50 ppm and bring the pH back to normal range (actually it's 3 lbs 11 oz of borax and 3 cups and 6 oz of acid if you want to be more exact but that is a lot harder to measure!).
    Since a normal box of borax has 76 oz in it you would need 9.5 boxes and 3 gal of acid to bring your pool to about 50 ppm borates amd bring the pH back in line.
    Add about 3boxes and a gallon of acid, brush the pool to mix and dissolve them, add another three and another gallon of acid and brush, then add the rest and brush.
    The borates will not go away unless you drain the pool so you really don't hve to do this. I added borates to my pool last july and the levels are still fine. You want 30 -50 ppm borates. I use the AquaChek borate test strips that I buy online. LaMotte and Proteam also make borate test strips.
    For more info check out these two threads:
    http://www.poolforum.com/pf2/showthread.php?t=4712
    http://www.poolforum.com/pf2/showthread.php?t=5419
    BTW, I have not needed to add ANY acid to my pool for the past 3 months! pH has held steady at 7.6, TA at 80 (pool is NOT closed, I live in Fl).
    Edit: Also,I have ordered the Aquacheck strips from here
    http://www.diywatertesting.com/
    Cheapest price I could find, free shipping, and I got my oder in 3 days!
    Thanks! This will be very helpful.
