Thread: Storm Aftermath
    Default Re: Storm Aftermath
    I think Carl has given you good advice. But, my question is, wouldn't you have to unhook your cover all the way around to be able to dribble the bleach all around? Seems to me, that would be a big pain and not worth the trouble. If it can be done easily, then go ahead.
    I agree with Carl that you are probably fine for now. Algae isn't likely to grow with water temp of 38. However, both Al and I had slight streaks of algae when our water temps were under 50. In fact, he has a pretty interesting picture on here somewhere where he had algae growing under ice in his pool. During the winters where I do cover my pool, (didn't this year), I will usually go ahead and start running the pump/filter with the cover still on probably in early April. This way I can add bleach through my skimmer if the cl level is too low and keep algae at bay until I do open. Still too early to swim, but like you said, springtime sunshine can cause the water temp to start to rise. That may be something you want to consider doing.
    At any rate, I think you are OK for now. Maybe when Al sees this post, he will find his algae and ice pic. Pretty weird!
    Welcome to the forum!
    Jul 2006
    Overland Park, Kansas
    Thanks for the thoughts on how best to handle this situation.
    I like the idea of watching the water temp and then firing up the pump/filter in early April or whenever the temp starts to get up to 50 or so.
    Unhooking the anchor straps for the cover one side at a time could certainly be done, but it would be a pain.
    Also, this may not be the proper area to ask this question, do I understand that Ben is currently not accepting any orders, even for refills?
    Quote Originally Posted by DRichter4764 View Post
    Well, it is off topic, but no, if you need quick response you'll need to get the refills from Taylor or Leslies on-line. If you have the ps-233, the refills are standard Taylor brand. If you have the PS-234, you'll have to check the testing forum for info on which Taylor refills are the equivalent. For example: T/A uses Taylor 0007, 0008 and 0009 as the reagents and I believe Ben calls them T/A 1 T/A 2 and T/A 3.
