Results 1 to 10 of 20
Thread: When do you open your pool?
    Default When do you open your pool?
    I live in Michigan, this is my first winter with the pool in the backyard, when do most people open up their pools for the summer? Mid-May?
    My plan is to have the PB open it for me. What do they need to do other than add a few feet of water to my IG? Is it stupid to be paying someone to do this?
    Indiana.
    Default Re: When do you open your pool?
    Quote Originally Posted by Jeffski View Post
    I open mine when the water hits 60. Varies quite a bit from year to year. The whole winterization/de-winterization process is pretty simple. Don't know if I'd say it's stupid to pay for it, but it only takes a couple of hours for me, including pump and lines preparation, removing the board and stand, all of the ladders and rails and installing the winter cover.
    Michigan
    We live in Michigan also. We used to open at the end of May, but we might start opening sooner and just use the heater alot more.
    The first year we had the pool, we hired them to open and close it. All we did was watch exactly what they did. From then on, we've opened and closed it ourselves. It's quite simple really.
    Good luck, and happy swimming!
    Why BBB? Because money can't buy happiness, but saving it sure can!
    It's not hard to open your pool. There's no magic. You have to add enough water to be able to run the pump and filter. You hook them up, make sure all the returns and drains are uncapped and open and all plumbing is hooked up.
    Then you have to clean it up. Lots of vacuuming usually.
    You need to test your water and find out where you are, then adjust it as needed.
    Mine stays open year round...but we don't have near the severe cold that you do. My kids went swimming yesterday!!
    My pool stayed uncovered all winter. Checked it a few days ago - water temp was 60 and I had no chlorine. So, I topped off the water level and hooked up my filter and pump and added a couple of bottles of bleach. Temp here in the low 80s today. Hope to get my solar panels hooked up before too long. Don't want to waste all the warmth! One problem we have is that with all the flowering trees, there is a ton of stuff that falls in the pool in early spring until all the leaves come out and replace all the buds. It makes quite a mess in the pool. We should be swimming by late April or early May hopefully.
    Edit - checked it today, water temp is up to 67. Up 7 degrees in the last 4 days.
    Hot Springs, AR
    Had ours open for about 3 weeks now, waters beautiful! Outside temp hit 81 degrees today and the pool is at 71 degrees so the kids and I jumped in! Once we got used to it, it wasn't that bad, but the INITIAL shock was a LULU !!!
    Cheers to all for a wonderfull summer!
    Todd
    15'X30' Muskin Fairmont, 1hp pump w/Hayward Filter
    Honesdale PA
    Just measured 8" of ice in mine in Northeast PA. Bah.
    Smile Re: When do you open your pool?
    While openig a pool is probably easier than closing one (properly), there are a couple of things that haven't been mentioned.
    Make sure all your plumbing connections at the pump/ filter are not leaking (lubing and keeping sure that any "O-rings" stay in their grooves) for unions (aka quick connections), retefloning (after removing ~most of the old tef) any threaded connections. This also includes the various air relief and drains on filters, pumps and filters. ---- Just make sure that you aren't leaking any water nor drawing any air in on the influent side of the pump. IF IT'S ~RUBBER - LUBE IT LIBERALLY WITH A SILICON OR TEFLON BASED LUBE!!!!!!
    Clean the cover (obviously - only if you covered the pool ) and let it thoroughly dry before folding it and storing it for the summer;
    1) Drying the cover on your lawn, too long, can kill the grass
    2) Fan folding (or 'sailor folding') will make the installation easier next fall (to do this get 2 people and stand at the back edge of the cover, each of you place your foot ~ 3' in and pull the cover back to the edge, step on the cover at the fold and repeat until you have a nice 3' 'fanfolded' cover, each person starts at their end and makes 2 - 3' folds until you have a nice (and easily mannaged) 3 X 3 cover which can be easily stored for the summer. ** mice and other critters tend to make their homes in stored covers - do whatever you have to to prevent this.
    If there's a lot of stuff on the deck sweep or rinse it away before it goes in the pool (optimally, this will have been done before removing the cover)
    The rest you know, remove any large debris, check your chem levels, & shock and adjust the other levels.
    Enjoy a trouble free swimming season by doing things the "poolforum way"
    I live in Iowa and I open my pool at the end of April. I get tired of looking at the covered pool. The water is to cold to swim in but this gives me a couple of weeks to get the water clear and the chemicals just right so that I can turn on the heater by mid May and swim...weather permitting of course. If nothing else, a beer tastes better looking at an open pool than a covered one!! :-)
  1. pool open for spring
    By heyjude in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-20-2012, 04:38 PM
  2. The pool is OPEN!
    By AnnaK in forum General Interest
    Last Post: 04-16-2012, 08:51 AM
  3. How NOT to open your pool
    By TimWillin2 in forum Dealing with Algae & Slime
    Last Post: 05-16-2008, 05:46 PM
  4. Trying to open pool
    By Bekka in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-30-2007, 01:12 PM
  5. Pool about to open...what do I do?
    By albertgarrido in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-22-2006, 10:49 AM
