Results 1 to 10 of 18
Thread: How long to run your pump
    Lafayette, IN
    Default Re: How long to run your pump
    Have I been wrong to run my pump 24/7?
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by scsteven View Post
    The only thing it hurts is your pocket book. So if your interested in saving some on your electric bill, you can fine tune your run time based upon what the pool needs and how clean you really want it. 2 turnovers should be more than enough.
    Mark
    Do any of you guy use a timer for your pump? I'm the type who'll forget to turn it on, or turn it off at least twice a week...
    I have had mine on a digital outdoor timer, but i'm scrapping it this year and going to analog, the digital drops the program every time we get a "blip' and being out in the country, blips are relatively common, the worst that will happen on an analog is the cycle will be off by x hours - x being the length of the power outage, but a blip can shut it down for a week if I'm away.
    West, Texas
    I have my pump on a timer, I run mine from 2AM till 4AM then from 1PM till 7PM
    Boyd
    27' Round AG, 17,204 gallons, sand filter
    Proud Father of an Army Soldier
    Central Texas
    Just long enough for the Polaris to get most of the pillbugs off the bottom.
    About 2 hours usually does it for now, but summer may need more.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Quote Originally Posted by matt4x4 View Post
    Wow, doesn't the digital have a battery backup? That's crazy that it gets killed everytime the power flickers.
    Tennessee
    I have solar heating so I run the pump when I have strong sun. I have the pump set up on my home automation system. The system triggers the pump based on light sensor. If I have a day with no sun the system runs the pump for 2.5 hours around noon.
    Quote Originally Posted by medvampire View Post
    Sounds like an awesome setup. Tellme more about the light sensor.. any specific parts I'd need to set something like that up? I'm thinking of doing something very similar to that setup, but I didn't know there was much technology out there to run it based on weather conditions..
  1. How long to run pump
    By tnalaskan in forum Pool Equipment & Operations
    Last Post: 07-06-2012, 12:50 PM
  2. The pump is dead, long live the pump!
    By maryberrye in forum Above-Ground Pool Construction & Repair
    Last Post: 07-05-2011, 01:38 PM
  3. How long to run pump?
    By jnorris in forum Pool Equipment & Operations
    Last Post: 07-22-2006, 11:42 PM
  4. Pump-how long to run?
    By howbout in forum Pool Equipment & Operations
    Last Post: 04-27-2006, 02:57 PM
  5. Pump-how long to run?
    By howbout in forum Pool Chemicals & Pool Water Problems
