Thread: Help with test kit instructions
    kevincad is offline Registered+ Thread Analyst kevincad 0
    Snellville, Georgia, U.S.A..
    Default Re: Help with test kit instructions
    Each drop is 0.5ppm. Welcome back to the forum!
    Also, while I have your attention, the other reagent is five drops, to test for free chlorine?
    Man, I wish I hadn't lost the instructions!!
    The R-0871 (the one we were discussing above) is the one that tests for free chlorine. I believe you are now talking about the R-0003 which you do after the free chlorine test to test for combined chlorine and you are right -- it is 5 drops. After you add the R-0003, if CC is present, your sample will turn pink and you then again add R-0871 one drop at a time to find your CC reading. If the sample does not turn pink, then you have no CC. Hope this helps.
    That's the ticket! Thank you so much!
  1. Aqua chem 3-way test kit instructions
    By FNC1962 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2012, 01:11 PM
  2. Instructions for PS234 test kit
    By Poolidiot in forum DPD-FAS based testing
    Last Post: 02-25-2007, 02:11 PM
  3. CYA reagent refill instructions?
    By salinda in forum DPD-FAS based testing
    Last Post: 08-16-2006, 06:17 PM
  4. Where are the instructions for PS234
    By ksturge in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2006, 10:44 PM
  5. Help no instructions with my 6 way test kit from walmart
    By peggles0224 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2006, 08:45 PM
