Results 1 to 10 of 49
Thread: help with adjusting please
    Default Re: help with adjusting please
    Poolhelp 101, you say you have brown stains. First thing to do is find out if they are metal or organic. Hold a vitamin C tablet on the stain and see if it disappears. If it does then you probably have iron staining and ascorbic acid will remove it. If you read through the Stains and Metal matters section of the forum you will find a lot of info on how to use ascorbic acid. Look for posts by Mbar (Marie), she is the forum's resident stain expert!
    Even Chem_Geek loses his head from time to time!
    Waterbear is ABSOLUTELY correct: Phosphates can be/should be ignored UNLESS all corrective measures for algae-killing fail. 99 out of 100 pool store guys will sell you a phosphate-remover (expensive) that you don't need, but Evan won't.
    I'm a super-minimalist: I don't like adding anything that's not needed. Only Polyquat 60%.
    thanks to everyone for responding.
    i do still have some brown stains and i will get the vitamin c and try that as soon as i can. also the pool is not cloudy to the point i can't see the bottom, it's more a hazy look.
    this evening we have had a hard rain, cl 5.0, ph 6.8, ta 150, cya 50 and i cannot get a reading for the hardness. i do have a sand filter, vinyl liner.
    i'm a little confused, so please help me, i'm not sure what you are telling me to do..
    1. i do have ph increaser, do i add that and how much or do i need to go buy borax? if i am to add any, how much
    2. do i add any more bleach and how much?
    3. and no more pool magnet plus, is that correct?
    4. anything else i should do.
    you guys are great in helping, i'm sorry i'm confused and need to ask more questions. but i certainly appreciate your guiding me again and helping me. Thanks!
    Marie (mbar) popped back in to the forum today. She had been AWOL during the winter like many people. She knows a lot about staining and metals. I'm gonna ask her to look at your thread and see if she has any advice for you.
    thank you so much for doing that
    but in the meantime, do i need to go ahead and increase the ph?
    if so is it okay to us ph increaser? i haven't added anything for the ph yet. or do i aerate as one instructed. this is probably dumb question, but how do i aerate it? i was waiting for you all to advise on that. thanks!
    mbar's Avatar
    Ashland, PA
    First of all take a deep breath and know that your pool will be cleared up soon. You have to know that the best thing to clear a pool is POP which is pool owners patience. Now I will try to address what I think is going on with your pool.
    If there are metals in the water and you shock a pool, it could cause the metals to fall out of the water and land on the surface of the pool. If you get some stains the best thing to do is to lower the ph to 7.0 add sequesterant (most of them are good) and let the filter run 24/7. Somethimes the low ph along with the sequesterant is enough to lift the stains back into solution which the sequestering agent will then bind with the metals and keep them suspended. Your water probably got cloudy because the metals were lifted off and this is in the water now - it will take a while to clear. You can add a chlorine puck to the skimmer since you have a sand filter. You can turn your return jets up to bubble on top of water so that your alkalinity(which is high) will lower while raising the ph. When the ph gets back to 7.4, add some acid to lower back down to 7.0 and keep the jets facing up. This is how you lower alkalinity. As your alkalinity is lowered, your ph will go up. If after a few days you still see some stains let me know, you can then get some ascorbic acid to remove the remainder of the stains and I will give you the directions on how to do that if you need to.
    One of the ways metals fall out of the water is with high ph and high chlorine. So you may want to keep your ph at the low end for a while, and make sure you keep a constant level of chlorine in the water so that you don't have to shock.
    If you have any questions, please feel free to ask - once you get your water balanced it will be easier to keep the stains away. Always keep a sequestering agent in the water - so if you add a lot of water make sure you add enough sequestering agent. I also find that using regular bleach is easier when you have metals in the water, because you can add the bleach slowly with more control. It is also a good idea to put a puck in the skimmer while getting rid of stains, because the water will hit the chlorine puck and if the metals fall out they will fall out onto the filter before they hit the pool. Just make sure you don't pour the bleach on the puck Add the bleach in by the return jets. Let me know how it goes
    Northeast PA
    Marie,
    Good to see you back again!
    Poolhelp101, listen to her, she won't steer you wrong! (and PoolMagnet is fine to use. Chemgeek just lost his head for a moment in a fit of passion! There is truth in what he said about many sequeserants causing phosphate levels to rise but it is NOTHING to be concerned about. Also, don't use pH up. It will mess up your TA. Use borax when you need to raise pH!)
