Results 1 to 10 of 16
Thread: Pool store refused to test my water...
    Default Re: Pool store refused to test my water...
    Carolina,
    They are probably tesing with DPD and not OTO. OTO (turns yellow) doesn't bleach out, which is it's one great plus. DPD (turns red) does. It will only test TC however.
    Edit: Whoops! My brain locked up too! I meant to say above that OTO only tests total chlorine! I was thinking that when I typed the last line above!
    Western NC
    Carolina,
    Yes, you are right, they do use the DPD test. I have the OTO test at home and I got confused for a moment (sorry - mommy brain)!
  1. First test from pool store
    By Texjag in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-22-2012, 10:03 PM
  2. TA Test - Me vs. Pool Store(s)
    By TSH in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2009, 09:54 AM
  3. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  4. TDS test at pool store? Salty taste in water??
    By Henrys514 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2006, 01:03 PM
  5. Test Results from pool store
    By jrtvols in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-02-2006, 02:59 PM
