Thread: Test results
    Attleboro, MA.
    Default Test results
    Here are my results:
    Ph 7.2
    TA 80
    FC 14.5
    CC 0.5
    CYA around 80
    I use bleach to shock and tri-chlor as my usual chlorine...still trying to finish off the huge buck from wholesale club.
    How do the numbers look?
    I put in a gallon of bleach about 2 hours ago before testing not sure how long that takes to build up the chlorine.
    Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
    rilesworld is offline ** No working email address ** rilesworld 0
    Nashville, TN
    Default Re: Test results
    Looks good, but keep an eye on your CYA if your going to use tri-chlor. It will be up over 100 in no time.
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
