Thread: aerating my pool
    Question aerating my pool
    I have a 24' ABG pool and it was very green. Now it is just milky.
    FC=12
    CC=0
    TC=12
    TA=130
    CYA=30
    Yesterday my ph was 7.8 and today it is below 6.8. I have added one box of Borax and have turned my return to aerate the water. How often should I test the ph? And should I even be aerating it or just adding Borax?
    My ph seems to be dropping even though I am aerating. Someone please help. The drops are almost showing no red in my water at all.
    Default Re: aerating my pool
    It doesn't seem likely that you had that dramatic of a change in ph in one day. My guess is that there was either a testing error on the 7.8 reading or on the below 6.8 reading. (You haven't added any muriatic acid have you?) Retest your ph again and see what you get. If it is indeed below 6.8, it may take quite a few additions of Borax to bring it up. When I add Borax, I usually wait about 3 or 4 hours before retesting and adding more. When you see the ph begin to rise, you should begin adding smaller doses than a box at a time so you don't overshoot in the other direction. As far as whether you should aerate the ph up or use Borax, in this case, if the ph is indeed below 6.8, you should use Borax because you want to get it above 7.0 ASAP. Readings below 7.0 are acidic and can damage your pool.
    Also, you should be running your pump 24/7 while trying to clear your water. The cloudiness is most likely dead algae that may take some time to filter out. Watch your filter pressure and when it rises 8-10 psi over clean filter pressure, backwash.
  1. Can constant aerating be a problem?
    By LindaE in forum Dealing with Alkalinity and Calcium
    Last Post: 10-01-2006, 02:51 PM
  2. Aerating Water to Get Rid of Iron
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-27-2006, 10:59 AM
  3. Stupid, STUPID ? and aerating...
    By poolmom06 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2006, 11:12 AM
  4. Aerating... Question.
    By Fueller in forum Dealing with Alkalinity and Calcium
    Last Post: 05-29-2006, 09:04 PM
