Thread: Pool Store Test Results
    St. Louis, MO, USA.
    Default Pool Store Test Results
    These are the results I just got back from the Pool Store.
    FC 2.4
    TC 3.2
    CC 0.8
    TA 131
    pH 7.6
    CYA 47
    This is after adding 4# of CYA and letting the pump run for about 4 days to let it all dissolve.
    I have a 11,000 AG vinyl liner pool.
    Any suggestions as to how the numbers look and what I should do?
    THANKS!
    Lloyd
    Default Re: Pool Store Test Results
    Quote Originally Posted by LFRoberts5 View Post
    FC 2.4
    TC 3.2
    CC 0.8
    TA 131
    pH 7.6
    CYA 47
    THANKS!
    Lloyd
    Your numbers don't look bad, except that I would shock it to get rid of that CC. Also, I'm not so sure that your CYA has finished dissolving in the water--it wouldn't suprise me to see it increase a bit more. How does the water look?
    St. Louis, MO, USA.
    Right now the water looks great!. How long do you think before all of the CYA is dissolved?
    St. Louis, MO, USA.
    Do I need to leave the pump running the whole time or just make sure I don't backwash it?
    Just don't backwash. You don't need to run the pump.
    But you do need to get your FC up to shock levels to get rid of that CC. I believe 15 is the FC you need. Then you should be just fine.
  1. Pool Store vs Test Kit Results??
    By hawkeye91 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2010, 10:58 AM
  2. My test results vs. Pool Store...now what??
    By Henrys514 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-16-2006, 01:32 AM
  3. Pool Store Test Results
    By Phulish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2006, 09:26 PM
  4. Test Results from pool store
    By jrtvols in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-02-2006, 02:59 PM
  5. pool store test results
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-01-2006, 06:20 PM
