Thread: Two questions (aqualuminator and also ladder mat)
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Default Two questions (aqualuminator and also ladder mat)
    1) Is it possible to put the aqualuminator on a timer? Not sure if this can be done because of the way the on/off switch works.
    2) Is having a mat under the ladder a must? We have a resin ladder in the pool which does not have a sharp bottom.
    Default Re: Two questions (aqualuminator and also ladder mat)
    Can't answer your question about the light on a timer. Somebody else will be along who can answer that one. But, about the mat under the ladder -------you do not have to have one if your ladder is totally smooth on the bottom. Mine is smooth and I do not have it on a mat. I have had the same ladder for about 6 years. When I replaced my liner last summer, the place where the ladder had been was fine. Now with the new liner, I again do not have mat under it.
    Texas
    Thanks mom...
  1. Colored (CAM/LED) Aqualuminator installed today. Waiting for night!!
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 07-18-2007, 05:26 AM
  2. HELP...I'm almost through with this *&%$ Aqualuminator
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 05-11-2007, 09:35 AM
  3. Leaky Aqualuminator...help?
    Last Post: 05-01-2007, 08:45 AM
  4. Winterizing the aqualuminator
    Last Post: 09-20-2006, 11:29 AM
  5. Aqualuminator leaking AG pool
    By Sharon2 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-18-2006, 11:14 AM
