Why on earth would you want to? is your filter putting something back into the pool it shouldn't? That could be the only reason I can think of that someone would want to put something on the return...Then I would say its time to fix the filter.....
Not sure about my filter.. that's why I want to put the hose on the return.. to see if I get anything.
Geeze.. it takes so many posts.. to get one answer.
Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
I've seen a commercial product filter bag for the returns but have not read about a homebrew alternative. Knee highs are thin, if you cut off the thicker part near the ankle maybe it is thin enough to screw right into the socket.
IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
Heating? Great info on why a solar cover saves $$$?
http://energy.gov/energysaver/articl...ng-pool-covers
[QUOTE=chuck9997;51485
Geeze.. it takes so many posts.. to get one answer.[/QUOTE]
Sometimes. But, there are a lot of nice people here who take their time to try and help. We certainly appreciate all of our posters who are willing to help!
Chuck, you can secure the nylon hose to the return with a rubber band. I use knee highs and secure them by the reinforced top so that there is plenty of material left in the pool to collect whatever may be bypassing the filter and still have enough room so that the pump doesn't blow a partially filled stocking off of the inlet (thereby ruining the test)
I hope this is more in line with what you were asking![]()
thanks everyone for your replies.. didn't mean to snap at anyone.. I am just so frustrated with the pool this year.. It has been a breeze for the last 4.. but I am seriously considering going back to mowing that part of my yard.. might be easier than figuring out this problem.
From researching here.. I probably have a problem in the filter.. that's causing the sand to blow out into the pool. But.. I really don't look forward to opening up the filter and investigating.. I am not very mechanical.. Is there a step by step guide to filter maintenance anywhere?
A guess but thinking its your laterals?.....Is it blowing air bubbles back in or anything else? When you backwash do you run a rinse cycle for very long before turning the multiport back to filter? I did in fact see a post or two here from one of the guys Al or Dave maybe? that went into a pretty good detail on how to check....Maybe use the search and check "laterals"
Janet's post in another thread details how to service the filter.
It is titled... for those with sand blowing back..... you may have already found it.
We had problems with sand flowing in pool this year too. We replaced the multiport valve, gasket and checked the laterals after emptying sand using wet dry vac and replaced sand. (We decided to replace valve because it was cracking from exposure to elements)
It wasn't too big of a job, but then again, I was just the gopher![]()
