Results 1 to 10 of 11
Thread: Should I adjust these numbers for fiberglass
    Jul 2006
    Default Re: Should I adjust these numbers for fiberglass
    Thanks. The ph was 7.4. I guess I'll have to shock next week. (I want to use the pool this weekend. When you mention holding the chlorine overnight, do you mean absolutely? Like if I check it at 11:00 pm and it's 15.2, then it should be 15.2 at 6:00 am? Also, how do I lower the calcium? Will it affect anything else? Thanks for your help.
    Tisha
    mbar's Avatar
    Ashland, PA
    You can shock overnight - it will go down overnight, and you can even swim in the pool with the chlorine up to 15ppms with a cya of 30 (you can even swim in a pool with higher chlorine). The only thing is you may want to wear an old bathing suit in case it fades a little, mine never has when I swam in my pool with 25ppms, but the chorine won't hurt you. It is better to swim in high chlorine then in anything else that is growing in your pool The faster you get chlorine in the water, the faster it will clear up. You will need 4/1/2 gallons of 6% bleach or 4 1/2 bags of shock to get it to the porper level. I wouldn't use cal hypo, because that is going to add calcium to your water, and the only way to get rid of calcium is to do a partial drain and refill. If your water is clear when the algae is gone, then I wouldn't worry about the calcium, 290 is still in range. Yes, the way to be sure that all the algae is gone is to test after the sun goes down, and early in the morning to see if the chlorine didn't change. Also keep your filter running 24/7 and brush and backwash as needed while you have algae. Good luck
    Northeast PA
    Jul 2006
    Thanks! You're always a great help! The cc confuses me a little bit. I thought that anything less than .5 was ok. Though I would prefer it at 0 of course! My original post may have been misleading, the low FC was from the hot sunny weather we've been having lately. The pool has been holding cl since I shocked about a week ago, but I'm not sure if it held totally.
    I am actually enjoying learning how to take care of this pool. After the algae outbreak I kind of took over from my husband who was more than happy to let me run with it. Thanks to these forums he thinks I'm a genius!
    As always, Marie gives great advice. She has a beautiful fiberglass pool. I was fortunate enough to get to see it and meet her this summer. Of course, ideally, your cc reading is 0. That is what we all shoot for, but, I say don't worry at 0.2. Many people will have a slight cc reading. If it goes over 0.5 is when I suggest shocking.
    mbar's Avatar
    Ashland, PA
    Yes, I did misread your post If you are finished dealing with algae, then everything is fine. You still didn't say what your ph is, I know my water gets a little cloudy when I have alkalinity above 100 and my ph goes over 7.6. Everyone's pool reacts differently - as long as your water is clear and you don't have any staining, then your numbers are fine. Just keep up with the bleach, and don't let it get low, or you will end up with algae again. You can take chlorine up at night to get rid of the cc.
    Watermom, thanks for the kind words, it was wonderful to meet you, and your son. Hope the weather isn't too hot back home for you
    Northeast PA
    Jul 2006
    Marie
    My ph is at 7.4. I don't think it has ever been to 7.6. I do have a little bit of staining which I thought resulted from shocking. I added 1 bottle of Jacks Pink Stuff, but it didn't really do anything. I am going to try the ascorbic acid stain treatment as soon as it comes in (ordered it on Thursday) and then add 1 1/2 qts of the Pink Stuff. I'll save the other half as maintenance doses for the rest of the season. Does it sound like I'm on the right track?
    Watermom
    It was hot as heck all this week until yesterday. Now it feels like we're in a cold front, about 84 degrees and not humid!
    Thanks.
