Results 1 to 10 of 18
Thread: Baking soda turned my pool green
    mbar's Avatar
    Ashland, PA
    Default Re: Baking soda turned my pool green
    I think the water just got saturated with adding it all at once . What is your calcium level? If it is high, it could be carbonates falling out of the water. If it doesn't clear up after a few hours add some acid to take the alk and ph back down. Make sure you do just a little at a time and wait 2 hours in between tests. Then you can start to raise them again slowly testing in between additions. You should always do this when adding baking soda or borax.
    Northeast PA
    Jul 2006
    Thanks for the resonse, your scenario is pretty much what I was hoping to hear. Testing now indicates my TA is at 100, which is where I wanted it so I am hoping that everything will settle down by morning. My ph remains low at this point, but my understanding is that baking soda will not bring the ph up a lot so I was expecting that and will deal with it after I get the water clear again. I am hoping that I won't have to add any acid to bring things down but will do so in the morning if things have not cleared up.
    Jul 2006
    I know, and I want to raise it as soon as possible. However, if this green is not cleared up by tomorrow it seems as if I will have to lower it first. I am aware that I should have added the baking soda more slowly but am an impatient person and just could not imagine my water responding like this.
    Do you think it still makes sense to bring TA and ph down if the water remains cloudy and green (even if the TA is reading 100 as it does now and the ph remains low)?
    mbar's Avatar
    Ashland, PA
    If your alkalinity only went up to 100, and your ph is low, then I'm not sure that is what turned the water cloudy and green. Do you know what your calcium is? Has the water cleared up at all? I would get the ph above 7, just add borax one cup at a time, testing after 2 hours. In the future you can use Arm and Hammer's washing soda - it will raise both alkalinity and ph at the same time. But for now just use the borax. Post a full set of numbers tomorrow, and we may be able to see what is going on. Sometimes if you have iron or copper in your water, and the ph and alkalinity go up it can react with the chlorine and turn the water green. In this case you would need to add a sequestering agent.
    Northeast PA
    Jul 2006
    Just tested this morning (the water is still green and cloudy but perhaps a shade lighter). TA was still 100 and ph was still low off the scale (below 7). I did add a cup of Borax. Chlrine was fine at 5 and my kit indicated no calcium hardness (the sample did not turn red after adding the agent so didn't bother to add the other drops to make it turn blue. Should I?). I have no way to test for copper or iron so will take a water sample to the pool store as soon as they open.
    Forgot to mention last night that the baking soda does seem to have left a soapy film on top of the water. Not sure if that matters or not.
    Jul 2006
    Just a quick update and then I am off to the pool store. I did add a cup of Borax before I posted this morning. I just re-tested my ph and it is still low but the greenish color appears to be clearing somewhat and the film on top of the water seems to be leaving as well. I am off to get the water tested for metals now.
