Thread: What Are the Correct Numbers For a SWG Pool?
    Default Re: What Are the Correct Numbers For a SWG Pool?
    Looks like you have been doing your homework! You are pretty much on target except the chlorine readings. With a cya of 60-80, a FC of 3 is too low. Take a look at the "best guess" chart again.
    Somebody else will have to answer the part about the temporary water filter. I have no idea where you would get one of those.
    Enjoy your pool!
    Actually, Salt pools seem to operate fine at a FC level of 3-5 ppm even though the CYA is 60-80 ppm. Many posters on this forum with salt pools have reported this.
    If you maintain your TA on the low side (about 80 ppm) and maintain your pH at about 7.5-7.6 you will get better pH stability becuase of less outgassing of carbon dioxide.
    The filter you are talking about is commonly called a 'fill stick'. You can google that to find out more.
    If your well water tests negative for metals then you probably don't need one.
    Also, adding borates to 50 ppm has been shown to be helplful in salt pools by reducing santizer demand and stabilizing pH. Search the forum for 'borates'.
    Did you have the "Total Control System" installed or just the Autopilot Digital? The Total Control inlcudes and acid tank and pH and ORP controllers to automate pH control and chlorine levels. The Digital will not maintian pH without manual addition of acid to the pool.
    Thanks for your help. I had the Total Control installed that has the automatic acid tank so it automatically adds acid when I need it to lower PH.
    I have spent some hours reading and searching through threads to get through all this! I think I understand most of it now.
    How do you test for metal in your water?
