Results 11 to 13 of 13
Thread: If chlorine is kept at proper level, is shocking ever necessary?
    Default Re: If chlorine is kept at proper level, is shocking ever necessary?
    Thank you, JJParish, for the kind words! Glad your pool is not giving you problems this year, and it's good to see you back!!
    Thanks for the help everybody! It took less than two days to clear up after I used plain bleach. By day three it was crystal clear.
    Before:
  1. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 12:41 PM
  2. Proper Measuring Level BBB (Hot Tub)
    By mjones0089 in forum General Interest
    Last Post: 06-29-2012, 05:45 PM
  3. High PH level while shocking pool question??
    By Pipecrew in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-04-2011, 03:07 PM
  4. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
