Re: Hole in Liner
Draining the pool as I type this... Will update everyone on my results, if they don't find me floating face-down in the pool from hypothermia. I'm hoping to drain the pool to about 2 feet, which should enable me to patch the holes without getting my torso into the water. Then I'll fill the pool another foot of water so it is just under the return. Hopefully I can close tomorrow.
