Re: Help with picking pump/filter system.
Poconos, Too much pump/not enough filter?? I am willing to give it another go. Would the 150# filter and a 1/2 or 3/4 hp be a good fit? What I meant by pressure dropping was. The pressure of the water coming from the return was dropping. I can feel the water coming out of the return was not as strong. My problem with backwashing is I really don't have anyplace to run it to. It is over 100 ft to our ditch (we do live in the country) out front of the house. However, if I can get my filter system set up and functioning properly I assume backwashing would be less frequent. Again, thanks for all the suggestions and help.
Dave
