Re: Hayward SP problems...new to pools..
Ok...changed out the gauge tonight and it immediately dropped to 15 psi. Didn't have it wrapped well with teflon tape..i think i went the wrong direction with it...anyhow, a small leak is coming from the threads at the gauge, so i'll fix that tommorrow.
Tightened the two screws on top of the sand filter and checked the gasket at the basket just before the pump...i've still got bubbles coming in. I can't find a spot where water is leaking anywhere(would that be the case if air is getting in?)
I did move it to recirculate, but i didn't notice any change with the bubble issue after that. I know Aylad mentioned checking the gaskets and seals...other than the one in the basket, where else would you recommend checking?
Thanks,
Kash
