Thread: Shock Question
    hannadock Guest
    Default Re: Shock Question
    Thanks I starting checking everything out. I only use 3 items, bleach, borax and soda. Tablets in the skimmer. I don't have the products but they came from Dehaney's Waterwarehouse. I'll start reading. Thanks again for the response.
    If you are using tabs in the skimmer, then you are using more than just bleach, borax and baking soda as the tabs are most likely trichlor. Let us know what type (ingredient) the tabs are and the "shock" as Janet suggested above. We will also need a set of current water testing results from a drops-based kit instead of test strips. The, somebody here can help you get started. Welcome to the forum!
    Right. Without proper testing we cannot help you.
