Re: Help with stain removal and metal free
Yes, sometimes it can take a week or more to get the water to hold chlorine. Leave the ph at 7 while you continue to add chlorine. Just keep checking it and add more chlorine to bring it up each time. As soon as all of the ascorbic acid is gone, the water will start to hold chlorine. It's good to keep the ph low while adding chlorine so that you won't get any stain. Once the water holds chlorine you can let the ph get a little higher. Just remember that if the stain starts to come back, take the ph back down and add more sequestering agent.
Northeast PA
