A couple of things are making it difficult to know what to tell you to help. Your cya readings are all over the place. It makes a difference in how much chlorine we recommend that you add. Also, we need to know what your cl level is. Not just 5+. Can you use the dilution method described above and try and get a more defined reading? Also, try your cya test again. I know your pool store did it for you, but many pool stores give rather "shaky" readings and we are pretty apprehensive to rely on them. Someone else can better advise you about cleaning cartridge filters. I have never had one.
