Thread: Milky Water and low PH
    Jul 2006
    NC
    Default Milky Water and low PH
    We've been 'shocking' our water for the last week (it wasn't covered and got swampy) and it's in pretty good shape right now except for the PH. It will look pretty good (the slightly pink color for ideal in the test kit - I can get an exact number if needed) at some points and other look almost clear, more a slight yellow but barely even that. It seems to be different about every day. The water is milky too. Alkalinity is good. Any ideas?
    Default Re: Milky Water and low PH
    You need to post current water testing numbers for us to take a look at. Without it, we can't really help much. Also, tell us exactly what you have put in the water (not just 'shock' but ingredients.) Also what type of test kit you used and what type and size your pool is. Then somebody here can better advise you.
    Jul 2006
    NC
    I understand It's a 13,000 gal vinyl above ground pool. Right now here are the numbers (as best I can tell from the colors/ranges by them):
    FC - 4.0-5.0 (orange-ish, not dark orange)
    TC - 3.0 - 3.5
    PH - 6.8 - 7.0 (in the orange, but VERY light, almost clear)
    Alk. = 120
    Hardness = 100
    Thanks!
    Pam
    La Jolla, CA
    Pam
    I would recommend getting a FAS-DPD kit. You numbers are a bit off.
    Your free Chlorine cannot be greater than your total chlorine.
    Remember your free chlorine plus combined chlorine equals your total chorine.
    Also, knowing what your CYA level is will be helpful
    The level of chlorine you need depends upon your CYA level.
    My pool has a CYA level of 40 so I keep my FC and TC level at 4-5
    I have no CC. (You don't want any CC)
    You can use borax to raise your pH. Also most if us use unstablilzed chlorine.
    Plain old bleach. This won't raise your stabilizer levels (CYA)
    If you have CC, you will need to shock your pool until it clears
    Jul 2006
    NC
    Thank you - I will get the tester - it's one of the ones sold here right?
    I will get the cya numbers. I know we had to raise it because it was very low when we started. I forgot to say, also, so that I use just straight bleach so my cya won't get too high - I raised it separately.
    I will double check that I didn't misunderstand the cholorine numbers. Hubby checked 'em for me while I was in the middle of something else and I may have switched them.
    La Jolla, CA
    There are many kits out there. One on this site from is fine.
    Or the Taylor 2600. Bottom line it is one that uses FAS-DPD for measuring chlorine levels.
    That is the one that uses the powder and drop titration.
    As far as CYA goes, your judgement is correct. You should use non stabilized chlorine and raise your CYA separately. A ballpark number is a 10 to 1 ratio.
    Meaning if your CYA level is 30 you will need approx 3ppm of FC
    If your CYA is 60 you might need 6ppm
    Rough guidelines but reasonable
  1. trying to get my pool un milky
    By cdawg in forum --cleanup--
    Last Post: 06-26-2013, 09:52 AM
  2. Milky cloudy water - concrete dust? At a loss.
    By lady.k in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2013, 11:38 AM
  3. Replies: 3
    Last Post: 07-13-2011, 04:43 PM
  4. Cloudy,Milky pool floc troubles! help!
    By NicolieM in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-29-2006, 12:21 PM
  5. milky white water I suspect from cal hypo any thoughts
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 07:42 PM
