Results 1 to 10 of 11
Thread: Waitin' on Summer
    Marion, OH
    Talking Waitin' on Summer
    I live in central Ohio. We opened our pool one week ago, and, thanks to the knowledge I've gained on this forum, our pool is sparkling clear already. Here are my test numbers from this morning:
    10,000 gallon vinyl in-ground, sand filter pool, heater (not on yet)
    CL - 5
    ph - 7.6
    Alk - 110
    CYA - 40
    Here in Ohio it's not even above 70 yet and the nights are in the 40's , so I'm just waiting on Mother Nature to quit being pissed at us here in the Buckeye state. So my question is should I add Borax and play around with the pool chemistry while waiting out this weather, or just sit back and keep testing and let the pool continue to look great? I should also mention that I use a skimmer sock, and added 1/2 cup DE throught the skimmer last night, all tricks I learned here and use religiously - you people are great.
    We also added 80 lbs water softner salt last year, which made the pool feel great, should we need to add it again this year? How can I test for salt?
    Thanks again for this forum. I've convinced several people to switch to the BBB method, but there are some unbelievers still paying $300 for startup chemicals. So far, I've spent $16 - and still have 6 96ox. bottles of bleach left. My pool is so much more enjoyable and easy!
    Default Re: Waitin' on Summer
    Quote Originally Posted by buckeyemom View Post
    CL - 5
    ph - 7.6
    Alk - 110
    CYA - 40
    I assume your water is colder than 70--llike 60. If so, you are just fine. In fact, even if the water was 80 I'd say your numbers are fine.
    But at 60 degrees, you'll get very little algae growth and should see very little dropping in your chlorine level. It's sort of in stasis.
    But keep testing!
    Marion, OH
    That would be a good assumption on the water - I haven't even had the inclination to put the thermometer on yet! And the chlorine level has stayed level for 2 days now. Okay - I'll keep testing - thanks for your response.
    Marion, OH
    Just as an update - I have a fountain in our pool which has been on for several days now. Yesterday was very windy here all day - my PH went up to 7.8. I shut off the fountain and lowered the PH to 7.2 using leftover "Lo and Slo". With my ALK at 110 should I add a small box of baking soda to stabilize the PH? I really enjoy using the fountain for looks and for the sound of the water.
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    But keep testing!
    I feel for you and waiting on summer. My pool is now 79 degrees (81 on the hot days).
    As for the testing for salt question, Taylor makes a salt test kit for this. I picked one up at my local pool store.
    The kids and I just got out of ours...the water hit 82 today. Yay!!! What a way to celebrate the last day of school!!
    Yeah, but we started August 4th. After many complaints about the heat during the first couple of weeks of school down here (they recorded temps on the school buses at 104+), this next year we won't start until Aug. 18th, but I think we go until June 2.
    Texas
    It is nice. Looks to be a great holiday weekend for us. 93 degrees and sunny....definate pool time.
    Marion, OH
    So ok, summer finally arrived in Ohio with 90+ degrees. All is well with my pool, and I have a fountain that comes out of the return and I really enjoy its sounds. However, I find I am fighting my PH rising to the 7.8 - 8.0 range when I leave it on for the day. Should I just keep adding acid to lower the PH and enjoy my fountain, or does the higher PH matter? (Inground vinyl pool - 10,000 gallons).
  1. Total Confusion - Last summer no probs but this summer big problems
    By ADHDPoolOwner in forum Pool Equipment & Operations
    Last Post: 06-14-2013, 02:01 PM
  2. Wonderful summer....let's keep it going!
    By ScottsPool in forum Intex-type Pool Setup & Operations
    Last Post: 07-18-2012, 01:44 PM
  3. getting started, first summer
    By nolensville in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-07-2012, 01:21 PM
