15 years from a pump. Pretty good. That pump owes you nothing. replace it.
Yeah...it ows you nothing but if it is a simple fix then save some $$$. Check this thread:
http://www.poolforum.com/pf2/showthread.php?t=4800
Could be something as simple and cheap as a crummy starter switch or bad starting capacitor.
it was a simple fix of just spinning the impeller and i have had no problems since. but i am concerned of the pumps age and wanted your opinion as to whether you think i should think of replacing it after this year. looks like my liner is also on its way out as it is also 15 years old also and i am now getting tears above water level.
If it would give you peace of mind then replace it. At least do your homework and figure what you want and where to get it when the time comes. I'd milk the old one for all you can. Then again, some people say I'm a packrat and never replace anything unless I have to.
i have a heater and i noticed a leak from the screw that is underneath the pipe that goes to the heater. this screw is what i have to unscrew when i close for the winter. i did tighten it when i opened it but there is a drip. i put a small pail underneath it last night and this evening the pail is full. when i emptied the pail i also noticed the water was warm to touch. i do not have the heater going yet so i couldn't figure why the water was so warm. then i noticed the pump motor was hot to touch...i have never noticed the motor being hot before, but i never really have ever touched it...is that normal? i shut the pump off and i could hear a hissing. i put my finger underneath this screw and the hissing stopped. can you give me advise about the leak and if that is normal about the pump motor. thanks
That drain plug is easy. Take it out and wrap about 10 turns of teflon pipe tape on the threads and screw it back in. Tighten until the leaking stops and be careful not to overtighten. As for the motor, they do run hot especially if in direct sun. Think I remember 140F or so on mine with an IR thermometer and that's inside a poolhouse. Could the water just feel warm because the air was cool? Only way a pump could heat water significantly is for the flow to be almost blocked and pumping only a trickle then all thre energy from the motor goes into heating water rather than moving it.
I just had a similar experience with an old Anthony that became sick beyond repair. The advantage of having a Hayward is that everyone carries new ones and can serve old ones.
You can get a new Hayward SP 1 HP at a store for $350 and for $300 plus shipping on the Net.
I got mine at Seasonal brick and mortar pool supplies store for $350 with two years P&L warranty.
If I were you, I'd take the old pump to a dealer who offers both repairs and new ones at a reasonable price. They can open it up and assess what needs to be done at what price. If only one or two parts need to be replaced and everything else is in good shape and there's no corrosion I'd go for repair if it's no more than $100. Otherwise I'd go for a new one.
Make sure you tell the dealer that you're committed to get his service/sale no matter what way you choose.
Be cautious : Some dealers may quote you $500 for the same pump. Make sure you have a quote of $350 or less before you bring it for repair.
This is my ticket for Heaven (when all's working..) :
22k Gal gunite IGP
38 SF DE filter, 1 HP Hayward Super Pump
Raypak 350k BTU Natural Gas Heater and solar cover
8 gal Liquidator with bleach
Dolphin robotic cleaner
Taylor k-2006 test kit
not had anymore problems with the pump. but i just tried to fix the leak at that screw but it didn't help, actually i made the leak worse so i may not know what i am doing. i took the screw out and wrapped the tape around it. when i turned the pump on it leaked worse so i took it back off. the screw is like a wing screw(i guess that's what you call it) and it leaks from the middle of the screw. can you tell me what i have done wrong or what i can do to fix it? thanks.
"...the screw is like a wing-screw and it leaks from the middle..." (Sorry, I've never mastered quoting from other posts) It sounds as though you might be describing a petcock. They can wear out. If it is then you can match it and put a new one in. Good auto parts stores are a source. Around here, NAPA would be my first stop. Hope this helps!
Hal
