Results 1 to 10 of 18
Thread: Just need to make sure....
    Default Just need to make sure....
    Hi,
    This is my 3rd year with the new pool and opening it this year was a suprise. It was deep green and very black at the bottom. After three days here are my numbers.
    FC = 7.5
    CC = 2.5
    ph = 7.2
    alk = 90
    cal = 80
    cya = 0
    temp = Very cold under 60 still.
    It is a cloudy white color. It seems to be getting better every day. I have vacuummed and scrubbed. I think I am ok but I am wondering if I should bump up the bleach.....
    Thanks for the great site and help.....
    Default Re: Just need to make sure....
    Thanks for the tip.
    My new numbers are
    FC = 16
    CC = 0
    ph = 6.8
    alk = 90
    cal = 80
    cya = 0
    Not sure why the ph went down so far..... I tested it 3 times to be sure.
    Seems like it is getting better.
    Is the best advice to fix my ph and keep FC above 10 until it is completely clear?
    Ok I got the PH up to 7.2 and I have been keeping the FC above 15. It is at 22 this morning. I am still cloudy and I am wondring if I should use a clarifier. The water is still cold so we won't be swimming any time soon but I want to get my water clear.
    Thanks again for the help.
    Give it some time. I know you are anxious, but sometimes the best thing you can do is to have what we call P.O.P. -- pool owner patience. Keep at it. Keep your pump running. I would not suggest adding a clarifier at this time. Sometimes getting in too big of a hurry to add extra stuff just causes extra problems. Especially since your water is cold and you won't be swimming for awhile anyways. It'll clear.
    New numbers
    FC = 30
    CC = 0
    ph = 6.8
    alk = 90
    cal = 80
    cya = 15
    temp = 62
    The weather here in NY is starting to break. Should be 82 today. I checked the pool this morning and my numbers are listed above. For some reason the PH is down again. I am headed to the store to bring it back up asap. It has been 8 days since I opened the pool and wife and kids are starting to get on my case. Any reason why my PH keeps going down? I have not put anything but bleach and baking soda in my pool in the last 6 days. Pool is still cloudy, pump running 24/7.
  1. How big a mistake did I make?
    By jojasc in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-05-2007, 11:05 AM
  2. Make sure I have this right - TA and CH
    By Trimom in forum Dealing with Alkalinity and Calcium
    Last Post: 06-19-2007, 04:37 PM
  3. Make sure I got this right...
    By steveinaz in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-04-2006, 02:52 PM
  4. When to make Chlorine?
    By Karin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-28-2006, 03:19 PM
