Re: Is TA 140 too high?
waterbear
Thanks for catching the typo. As far as lowering TA there is a sticky here on the forum that explains how.
One thing I have to caution you. This is a pool, not a science experiment You are starting to overthink things and looking for problems before they materialize.(I have been following your threads, as you know). Now I can debate the theoretical chemistry with the best of them (as the long timers on this forum well know) but I choose not to unless their is a REAL reason to.
My suggestion is to start ENJOYING your pool and stop worrying so much about water balance. That's wny we got 'em in the first place, right? You hvae been given advice. Don't overthink it.
BTW, the amount of bubbles produced by your pooskimmer should not have any major impact on pH rise since the amount of aeration produced is going to be small. This is what I mean by overthinking.
Thanks for all the advices. I certainly plan to enjoy my pool, as I've used to, once the weather gets better here and the pool is ready.
However, I’ve learned from my experience so far that if I don't follow the RIGHT balance and sanitation, there's more work and more trouble. Most likely this is why I got the pink algae last year, which was a pain to get rid of. Also, in the past my pH was never stable. Now I want a smoother operation. As for the aeration - I think I saw in this forum more than once that this changes the pH.
My pH already drifted in one day from 7.5 to 7.6, so what was said here about the need to lower TA was probably right.
All in all my plan is to start with a good balance first and than to enjoy the water with as little work as possible.
This is my ticket for Heaven (when all's working..) :
22k Gal gunite IGP
38 SF DE filter, 1 HP Hayward Super Pump
Raypak 350k BTU Natural Gas Heater and solar cover
8 gal Liquidator with bleach
Dolphin robotic cleaner
Taylor k-2006 test kit
